Date/Time: Fri, 03 May 2024 23:30:13 +0000
draw volume profile tool not functioning properly
View Count: 611
[2019-04-21 17:44:24] |
MMX - Posts: 119 |
This week I moved my main price graph to region 3 and I have spent hours trying to get studies and tools to perform just as they did perform when the main price graph was in region 1. As I write, the DVP tool still works perfectly with the price graph in region 1, but when I draw the VP when the price graph is in region 3 it becomes dead. It's there, you can see it in region 3, you just can't enable it, can't activate it, right clicking on it does not bring up the properties selection, it's dead. I've created and saved new defaults for the DVP, always using region 3 for the new default. That doesn't change anything, still works perfectly when in region 1, still dead when in region 3, what can I do?
[2019-04-22 02:04:43] |
We will check on this.
[2019-04-22 20:37:41] |
This will be resolved in the next release.
