Date/Time: Sun, 05 May 2024 00:45:28 +0000
Can I drag bulk orders in a defined range?
View Count: 573
[2019-04-19 18:02:10] |
user8222 - Posts: 21 |
Is it possible in sierra to pick two points on a chart and have it place bulk orders between the two, say 20 orders in a range? I'd like to scale orders in certain areas. Specifically talking about Bitmex btc trading. Thanks.
[2019-04-19 20:40:33] |
Not through the User Interface or any of the built-in trading studies. This is something you would have to develop using the ACSIL interface. You will find the information on ACSIL starting here: Advanced Custom Study Interface and Language (ACSIL) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
