Date/Time: Mon, 06 May 2024 19:22:13 +0000
User Question
View Count: 614
[2019-04-19 16:22:55] |
Sierra Chart - Max - Posts: 5607 |
I'm interested in giving SierraChart a shot, but have a few question first. 1. I use Interactive Brokers to place trades. Can I connect SC with IB? If so, how? 2. I trade options only. Am I able to place buy/sell Option orders on SC (when connected to IB) that routes it then to IB? And if so, is there a fee that SC takes? 3. Am I able to use an advanced trade management for Options buying and selling whereby you would see the actual stop and profit orders sitting on the chart itself, or is that only available for buying outright shares of a stock? Many thanks! Sierra Chart Support |
[2019-04-20 01:05:45] |
1. Yes this is supported. Refer to: Interactive Brokers Trading Service: Setup Instructions 2. Yes you can do this. You have to make sure to use the right TWS options symbol format. There is no additional fee. 3. Yes you can use Attached Orders for options: Attached Orders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
