Date/Time: Mon, 06 May 2024 22:17:03 +0000
TPO Autotrading
View Count: 953
[2019-04-19 15:32:10] |
User641335 - Posts: 2 |
Is there a way to set up an autotrading system based on a TPO study? I know that the source code for the TPO studies is not provided, but is there another way, perhaps through alerts? Specifically, I want to set up a system that detects when price enters a low-volume node (a region with abnormally few TPO blocks compared to the value area), and then places a long or short trade based on previous price direction. Thank you Date Time Of Last Edit: 2019-04-19 16:45:47
[2019-04-21 23:56:16] |
The answer is yes and it would be best to use ACSIL for this. You can determine the number of blocks per row with this function: sc.GetVolumeAtPriceDataForStudyProfile() For trading, refer to: Automated Trading From an Advanced Custom Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-21 23:57:28
