Date/Time: Fri, 03 May 2024 05:15:34 +0000
IB ESTX50 Eurostoxx 50 index
View Count: 771
[2019-04-19 08:54:23] |
User59879 - Posts: 66 |
I have been trying to add the ESTX50 index (DTB) to my watchlist, importing from IB/TWS. On IB/TWS it is known as ESTX50 and I can see the data, but I cannot find it under IB Indices (Watchlist / Find). So I have constructed the symbol name in the same way as the DAX index (ie. DAX-IND-DTB), as ESTX50-IND-DTB, but no success. Any suggestions? |
[2019-04-19 09:21:49] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings We have added this symbol to File >> Find Symbol >> IB Indexes. We included the currency code. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-19 09:22:18
