Date/Time: Tue, 07 May 2024 01:17:57 +0000
Orders being cancelled
View Count: 567
[2019-04-18 20:15:10] |
canyiah - Posts: 48 |
Im using Rithmic Data feed and in sierra this has happened at least twice where i had a position on i went to add it filled but was immediately closed. There is no profit management on or margin issues. Is there something in Sierra that would cause this to happen? ie_ position limits etc
[2019-04-19 10:14:50] |
No this is not related to Sierra Chart. We are not understanding the details of this. Refer to: Trade Activity Log Analysis: Support Assisted Trade Activity Log Analysis A Position Limit is supported but it is not likely you have set that. That can be set through Global Settings >> Symbol Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-19 10:15:34
