Date/Time: Sat, 04 May 2024 16:22:22 +0000
using cloud for data folder?
View Count: 987
[2019-04-18 16:21:08] |
tdug - Posts: 124 |
Hi, I want to be able to have a consolidate folder for my chartbooks. Would I be right in thinking that I can use onedrive for my data folder? If I do this, will it bring up runtime issues when working with realtime data? I am thinking it wont given the if I place the data folder into a local one drive folder, it will read and write locally before sync with cloud. The workflow I am then desiring is that I could close my desktop SC and then open the cloud updated chartbook from the cloud data folder and have all the same work saved? Many thanks in advance. Tim |
[2019-04-18 16:22:41] |
Sierra Chart - Max - Posts: 5605 |
This is not going to work for many reasons.
Sierra Chart Support |
