Date/Time: Sat, 17 Oct 2026 06:52:19 +0000
Indicators from Sierra Charts - how are they calculated
View Count: 1294
| [2019-04-18 10:25:35] |
| User266447 - Posts: 280 |
Hello, How can I know the definition and calculation of indicators I am using on Sierra Charts? I have in mind: a) Per cent change since open b) Wide Range Bar c) Preferred Stochastic - DiNapoli I will appreciate your support. Kind regards, Arek |
| [2019-04-18 15:53:39] |
| John - SC Support - Posts: 48239 |
Most of the studies in Sierra Chart have explicit documentation about how they are calculated. Those that do not are being worked on. For example, refer to the documentation here for the Percent Change Since Open study: Percent Change Since Open You will find the same for the other studies you reference. You will find all of the studies listed in the Technical Studies Reference, then just select the study you want to see how it is calculated: Technical Studies Reference For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
