Date/Time: Sat, 04 May 2024 01:58:25 +0000
BATS/NYSE / Second instance /
View Count: 550
[2019-04-17 16:14:24] |
User282016 - Posts: 3 |
Hello team, Can you please clarify the below points: 1. Is there any diffrence in quality of live data for stocks between BATS and NYSE except premarket and postmarket trading? 2. Just to confirm: is there any additional fee of using New instance of Sierra chart on the same computer? IS there any additional fee for using a separate instance on a seaprate computer? 3. Are Forex and CFD symbols excluded from number of real symbols that can be monitored simultaneously in case of owning relevant package? Awaiting your response. Thank you in advance. |
[2019-04-17 19:04:52] |
1. Yes there is large difference. There is a lot less volume on BATS. And there is no premarket or post market with BATS. 2. No. 3. Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-17 19:05:07
