Date/Time: Sun, 28 Apr 2024 20:14:04 +0000
Market Profile for Stocks (Nasdaq)
View Count: 1048
[2019-04-15 21:54:57] |
User226793 - Posts: 160 |
Folks, Can I construct TPO Charts for Stocks such as NFLX and FB?
[2019-04-16 15:20:23] |
User149226 - Posts: 16 |
as long as u have a 3rd party data provider that allows u to access equities u can do as u wish. SC works on every product but u need to b mindful of the data provider as some do not give u the option to purchase equity data.
[2019-04-16 16:52:27] |
The answer is yes, this is supported. You can use the Sierra Chart Historical Data service if you do not require real-time data: Sierra Chart Historical Data Service Or for real-time data you can use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-16 16:52:37
[2019-04-24 16:30:40] |
Does Sierra Data support the above?
[2019-04-24 18:52:07] |
Yes. Refer to the following for Stock Exchanges that are supported: Sierra Chart Exchange Data Feed: Supported Exchanges Just be aware that there is no Market Depth data for stocks. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-24 18:52:25
