Date/Time: Mon, 29 Apr 2024 03:31:36 +0000
Heiken Ashi lines?
View Count: 1379
[2019-04-15 15:23:45] |
Ryan Kane - Posts: 9 |
I would like to change the Heiken Ashi histogram from squares into lines? Is this possible?
[2019-04-15 18:12:35] |
This does not make sense. The Heiken Ashi study displays Open, High, Low, Close bars or candlesticks.
[2019-04-15 19:46:16] |
I am aware of the bars and candlesticks. However there are some tools that have configured the Heiken Ashi candles into lines. See screenshot--the green and red lines are coming from HA data.
Screenshot 2019-04-15 13.39.54.png / V - Attached On 2019-04-15 19:40:35 UTC - Size: 211.9 KB - 418 views |
[2019-04-15 19:58:08] |
SC Support Tom - Posts: 450 |
You can get Heikin-Ashi lines via Settings >> Subgraphs >> Graph Draw Type. The three relevant options are Line on Close, Line on Open, and Line on HL Avg. I have attached an image showing the results.
Date Time Of Last Edit: 2019-04-15 22:41:04
$INX Daily #1 2019-04-15 14_56_58.067.png / V - Attached On 2019-04-15 19:58:01 UTC - Size: 40.1 KB - 391 views |
