Date/Time: Mon, 23 Nov 2026 12:22:06 +0000
Cumulative Delta volume
View Count: 2797
[2019-04-15 12:35:02]
User338838 - Posts: 14
Hello, I kindly ask You how it is possible to get the cumulative delta volume represented in your graphs only with the numbers Ie not with histograms. Thanks best regards
[2019-04-15 17:44:36]
The easiest thing to do is to use the Numbers Bars Calculated Values study, which has an option to display the Cumulative Ask Bid Difference and resets with the start of the trading day. Refer to the documentation here:
Numbers Bars: Displaying Numeric Information Below Numbers Bars
There are also these Subgraphs available with that study:
Cumulative Delta Volume High
Cumulative Delta Volume Low
Date Time Of Last Edit: 2019-04-15 17:49:07
