Date/Time: Sun, 28 Apr 2024 22:54:58 +0000
E-Mini Euro FX Daily Chart Problem
View Count: 710
[2019-04-15 09:11:11] |
BrewTrader - Posts: 21 |
I've had a problem now for about 3 weeks. My FX daily chart of the E-Mini EURO FX E7 consistently produces an unusable daily chart for the current day. The chart shows the current day as a LONG red candle. I have updated the software several times (just upgraded to 1898 in fact) and I have copied a known good chart, changed the symbol but it still has the same error. Attached is a screenshot. Thank you, https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=27592 |
[2019-04-15 10:26:44] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings After that follow the instructions here to apply the symbol settings to the chart: Global Symbol Settings: Update/Apply Symbol Settings to Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-04-15 19:28:05] |
Yep, that fixed it. Thanks Randy |
