Date/Time: Thu, 12 Nov 2026 21:49:41 +0000
Right Align Yearly Historical Bars
View Count: 902
| [2019-04-14 10:51:05] |
| User462086 - Posts: 203 |
Hi, my chart's x-axis range starts at 1991 and ends at 2055. Without scaling up the x-axis, how do I right-align these bars so that the rightmost year is 2019? Many thanks!!
| [2019-04-15 10:33:05] |
You just have to increase the spacing between the chart bars so that the last bar in the chart is up to the right side assuming you have not set any fill space. Refer to: Working With Charts: Changing Bar Spacing Or you just need to increase the number of bars in the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-15 10:33:21
