Date/Time: Sat, 04 May 2024 14:01:18 +0000
Watch list cycle loses the symbol drawings.
View Count: 1194
[2013-11-21 05:07:49] |
reggytrades - Posts: 29 |
Please see attached two screenshots. First shows chartbook w/AUDJPY 5rng, AUDUSD 5rng charts. AUDJPY has a red trendline drawn. Second screenshot show the same chartbook w/ AUDJPY 5rng, AUDJPY 5rng charts. After changing the symbol from AUDUSD to AUDJPY the chart does not copy the trendline from the AUDJPY chart on its left. Thanks again.
aj au trendline - 11_20_2013 , 6_42_19 PM.jpg / V - Attached On 2013-11-21 05:06:28 UTC - Size: 294.21 KB - 419 views aj aj wo trendline- 11_20_2013 , 6_43_11 PM.jpg / V - Attached On 2013-11-21 05:06:50 UTC - Size: 290.44 KB - 546 views |
[2013-11-21 05:52:16] |
Did you set the chart to copy chart drawings from the other chart as explained here: http://www.sierrachart.com/index.php?l=doc/helpdetails72.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-11-21 06:34:40] |
When cycling through a watch list, do we need to set copy from another chart? Or does each symbol in the watchlist retain it's own symbol drawings? I'm familiar w/ use Chart Settings, "Copy Chart Drawings from Chart #'s" But it's much better, faster if the symbol retains its own drawings in a watch list. I was told that was so in Post #6468: "Chart Drawings do not become lost when you change the symbol of a chart." If I want to compare one symbol, for example, EURJPY, to the other EUR or JPY pairs, then to cycle through a EUR list or a JPY list would be much better if I could just use the watchlist as opposed to doing the copy setting manually in the Chart Settings "Copy Chart Drawings" dialogue. Can the watch list cycle be used like this without manually inputing the settings in the Chart Settings dialogue? Thanks for your help.
