Date/Time: Sun, 05 May 2024 05:32:21 +0000
Connection error between SC and IB! Is this SC or IB related?
View Count: 606
[2019-04-11 16:11:15] |
User606576 - Posts: 3 |
Interactive Brokers | Connecting to 127.0.0.1:7496 | 2019-04-11 22:19:25 Socket (1) | Creating socket. | 2019-04-11 22:19:25 Socket (1) | Connecting to IP: 127.0.0.1. | 2019-04-11 22:19:25 Socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-04-11 22:19:26 * Interactive Brokers | Failed to connect to the data and trade server. | 2019-04-11 22:19:26 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2019-04-11 22:19:26 * Socket (1) | Closed. | 2019-04-11 22:19:26 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-04-11 22:19:26 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-04-11 22:19:26 Interactive Brokers | Disconnected. | 2019-04-11 22:19:26 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-04-11 22:19:26 |
[2019-04-11 17:44:24] |
Follow the instructions at step 26 here: https://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php#IBResolvingConnectionIssue Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
