Date/Time: Mon, 29 Apr 2024 20:20:28 +0000
Chart footer date format setting
View Count: 1325
[2019-04-11 11:07:55] |
User376341 - Posts: 37 |
hi pls tell me where dates in snap are set i believe the leftmost has a separate setting |
date format.PNG / V - Attached On 2019-04-11 11:06:36 UTC - Size: 5.96 KB - 284 views Attachment Deleted. |
[2019-04-11 17:37:33] |
There is no way to control the format for the date labels at the bottom.
[2019-04-11 21:14:10] |
OK where is the format of the date for the Chart Values tool set please I remember removing the year see new snapshot |
crosshair.png / V - Attached On 2019-04-11 21:13:36 UTC - Size: 6.03 KB - 262 views |
[2019-04-11 22:58:55] |
That is controlled through Global Settings >> Tool Settings >> Chart Values.
[2019-04-29 19:58:05] |
Ok thanks unrelated to subject... is there a way to save chart-drawn trade data? After having used replay, and seeing the trades drawn, (and have saved the data from Trade activity log) Is there then a way to save that visual data, run a different replay and then load the initial visual data? |
[2019-04-29 21:23:37] |
Yes. Just run another replay using a different Trade Account and then you can switch between accounts: Auto Trade System Back Testing: Running Multiple Back Tests For Comparisons Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-05-01 08:25:46] |
This is a great solution for my issue 1.For some reason not seeing the horizontal lines plotted (in replays) at my attached order's target and stop levels, when using Sim 2 (3,4, etc) acct. did i miss something? 2. What setting to change the color from red in snapshot pls Date Time Of Last Edit: 2019-05-01 08:28:18
[2019-05-01 22:34:11] |
1. We do not see this when we try to reproduce what you are stating. Please attach a screenshot so we can better understand what you are seeing and let us know exactly what you are doing so we can see what may be occurring. Although refer to: Chart Trading and the Chart DOM: Viewing Working Orders Outside the Visible Price Range 2. The Chart Trade Mode Box background coloring is controlled by two settings: - Chart Trade Mode Box - Chart Trade Mode Box - Simulation Where the latter is used when the chart is in Simulation Mode. Refer to the following for these Graphics Settings: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart Trade Mode Box Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-05-01 23:17:09
[2019-05-06 23:38:35] |
Hi unrelated again :)... What is this dropdown called in the Trade Activity Log (attached file) |
Attachment Deleted. Attachment Deleted. |
