Date/Time: Fri, 09 Oct 2026 08:18:23 +0000
Watch List cycle loses symbol settings
View Count: 1831
[2013-11-20 22:04:31]
reggytrades - Posts: 29
Next file in watch list will not update the "Price Display Format" and "Apply Global Symbol Settings" in the "Chart Settings" dialogue selection boxes. Also the symbol drawings are lost. Is there a way to use the "next file" menu selection to cycle through an "Associated File List" which will display both the correct "Global Symbol Settings" / "Price Display Format"? As it is now I may have to create a separate chartbook for each symbol unless I can find another way.
[2013-11-20 22:06:33]
Do you have Global Symbol Settings set up for the symbol you are changing the chart to?
Chart Drawings do not become lost when you change the symbol of a chart. They are still there, but not necessarily visible. They may not display because you have got a different symbol in the chart. This is common sense.
Date Time Of Last Edit: 2013-11-20 22:06:53
[2013-11-20 23:26:55]
Thank you for your rapid response. I'm relieved to know it was just an oversight on my part. Yes, you were right about the global symbol settings for the price formats. Still getting a drop of trendlines drawn on a symbol when the symbol is changed. Any ideas? Thanks again for a great product. Please see attached two screenshots. First shows chartbook w/AUDJPY 5rng, AUDUSD 5rng charts. AUDJPY has a red trendline drawn. Second screenshot show the same chartbook w/ AUDJPY 5rng, AUDJPY 5rng charts. After changing the symbol from AUDUSD to AUDJPY the chart does not copy the trendline from the AUDJPY chart on its left. Thanks again.
Again, my mistake. Have attached the correct screenshot. Thanks.
Date Time Of Last Edit: 2013-11-21 20:12:59
imageaj au trendline - 11_20_2013 , 6_42_19 PM.jpg / V - Attached On 2013-11-20 23:49:42 UTC - Size: 294.21 KB - 735 views
imageaj aj wo trendline- 11_20_2013 , 6_43_11 PM.jpg / V - Attached On 2013-11-21 20:09:50 UTC - Size: 290.44 KB - 660 views
[2013-11-21 00:14:49]
The chart images look the same.
