Date/Time: Sat, 04 May 2024 04:12:19 +0000
Sierra Data Feed & IB
View Count: 592
[2019-04-11 01:43:53] |
User417302 - Posts: 66 |
I was just curious to know how Sierra's data feed interacts with IB's data? Specifically will the pace (or speed) in the t&s and in the dom slow down? Since IB's feed is not the best and the way they report t&s and the dom changes are a slower how does that affect Sierra's data feed? I just want to insure that there is no slowing of data coming into both t&s and the dom. Thanks, |
[2019-04-11 04:19:01] |
The Interactive Brokers data feed is ignored for a symbol that is receiving data from the Sierra Chart Exchange Data Feed. And it is also not even subscribed to either for that symbol.
[2019-04-11 12:19:25] |
Ok perfect thank you.
