Date/Time: Fri, 03 May 2024 13:44:22 +0000
Market Depth Historical Graph - NOT SHOWING
View Count: 1202
[2019-04-10 21:28:01] |
HAB-User115006 - Posts: 38 |
I have service package 3 bought directly from Sierra I am connected to Rithmic data feed I can see the DOM I have enabled the symbol to 'Record Market Depth Data', I see a depth file with todays date gets created and is increasing in size with new data After I add the study, I get the following message in the Log: "Market Depth Historical Graph | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2019-04-10 14:03:14 *" I already have realtime data via Rithmic so what do I need to enable on Sierra? |
[2019-04-11 17:39:27] |
You do need to change to the Advanced Service Package 5 for the Market Depth Historical Graph study: To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-11 17:39:53
