Date/Time: Mon, 29 Apr 2024 08:06:53 +0000
Accounting metrics for back test - way to create periodic report by-system/symbol/etc?
View Count: 663
[2019-04-10 17:11:26] |
Chad - Posts: 231 |
Hi. Is it feasible to use sc.CreateProfitLossDisplayString and/or sc.GetTradeStatisticsForSymbol during or after a backtest routine, which would have accounting metrics (PnL, drawdown, etc) as 'snapshots' every minute/hour/etc? If so, could it also be done by-system (strategy), assuming a parse of the Text Tag in Notes field?
[2019-04-11 05:06:51] |
Yes those functions can be used at any point during a back test. Obviously this can be done by an ACSIL trading system because these are ACSIL functions.
[2019-04-11 15:53:47] |
Chad - Posts: 231 |
Would using these functions in conjunction with a trading system built from the Spreadsheet System for Trading work as well?
[2019-04-11 18:02:42] |
Yes.
[2019-04-11 21:01:51] |
Chad - Posts: 231 |
Okay, thanks. One last question on this: in order to set the format of the returned strings as minutely, would I need to use sc.UpdateAlways = True and sc.SetDefaults::Input_SaveInterval.SetInt() as 60 for sixty seconds?
Date Time Of Last Edit: 2019-04-11 21:32:33
[2019-04-12 17:01:36] |
We do not see how we can answer this question. You have to make your own programming decisions. Understand you know what it is you are doing and what you need to accomplish.
