Date/Time: Thu, 05 Nov 2026 21:18:09 +0000
Highlight specific dates/times on chart
View Count: 1626
| [2019-04-10 00:10:08] |
| User264760 - Posts: 6 |
Hi, I want to take a FOREX economic calendar and plot past events on my chart. I can enter the dates/time manually and would like to know what is the best method to do this in SC. For example: March 15, 2017 @ 8:30 CPI report I would like to at least highlight the date/time and possibly see the type of report/event on the chart for backtesting purpose. Many thanks, Guillaume |
| [2019-04-10 18:00:42] |
Best thing to do is to use the Type Text tool and go to that particular date-time in the chart (Chart >> Goto Date-Time) and just type the text on the chart indicating the information that you want: Chart Drawing Tools: Type Text | Stationary Text Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
