Date/Time: Fri, 03 May 2024 05:22:00 +0000
6E on OEC using Sierra Chart Data Feed
View Count: 1117
[2013-11-20 19:15:27] |
drw112 - Posts: 21 |
Similar to my post yesterday about the multiplier on M6E but for 6E when using OEC. Currently the front month contract is not multiplied but the back months are being multiplied when doing a continuous contract. Can you verify that this is setup correctly and that I'm not just messing something up?
[2013-11-20 20:44:20] |
This is now corrected. Follow the instructions here to update the symbol settings: https://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings When that is done, reconnect to the data feed with the commands on the File menu. Go to the chart and re-download all the data by selecting Edit >>Delete All Data and Download. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
