Date/Time: Mon, 29 Apr 2024 16:37:55 +0000
4 Hour Chart
View Count: 2992
[2013-04-10 09:18:07] |
sonyclan1 - Posts: 7 |
Gentlemen my 4 Hour Chart seems to be out of synch with my Brokers Charts and the charts of my fellow Trading Room buddies. It seems to be 3 hours behind and a bar short. I have the time Zone set to +0 GMT/+1 BST. Is there any way I can synchronize the chart and keep the same Time Zone. |
[2013-04-10 09:29:10] |
You need to be certain that you have the same Time Zone setting and the same Session Times in Chart >> Chart Settings.
[2013-04-10 09:39:36] |
Start Time 00:00:00 End Time 23:59:59 New Bar at session start checked. Load week ends checked. |
[2013-04-10 10:12:07] |
This all seems fine, but what counts is the Chart Settings of the chart you are making a comparison to.
[2013-04-10 10:14:43] |
They are probably set to NY Zone.
