Date/Time: Wed, 04 Nov 2026 16:19:11 +0000
User drawn trend lines?
View Count: 1508
[2019-04-04 23:30:07]
User901353 - Posts: 26
Why do trend lines get all wonky after a period of time? I draw a perfect trend line touching the bottoms of my Renko bars and in 30 minutes or so they are nowhere close to where they were drawn. Is this an issue with trend lines or with the bars?
[2019-04-04 23:31:58]
And it is not because the bars have moved away from where the line was drawn. The bars continue at 45 degrees but the lines diverge quite a bit.
[2019-04-04 23:56:11]
Nevermind... it's a Renko issue. Found the docs... Lines/Rays or Other Chart Drawings Move After Drawing Them
[2019-04-05 08:30:15]
Yes that is the relevant documentation:
Just make sure the endpoint of the line does not go into the fill space.
[2019-04-19 18:51:51]
I have the Rays staying stable and I have set up an alert for when current price crosses the Ray. In each case where the price crosses the Ray I receive an audible alert. I would like to link this alert to a "Trading System based on Alerts". Is this possible or am I just wasting time?
[2019-04-26 04:33:42]
This is not currently possible with a Ray drawing but we will work on adding support for this.
You can reference drawings in an alert formula:
Study/Chart Alerts And Scanning: Referencing Chart Drawings
But the problem is that it is only the endpoints. So we need to change this to access the drawing value at any chart bar.
Date Time Of Last Edit: 2019-04-26 04:34:45
[2019-05-01 14:38:12]
It's great to hear you will be working on it. Thanks
[2019-05-02 20:33:56]
Working on what?
[2019-05-08 18:37:31]
"This is not currently possible with a Ray drawing but we will work on adding support for this."
From your previous response.
[2020-12-30 11:53:49]
User90125 - Posts: 715
This would be great for many users. Did SC implement this yet?
[2020-12-30 15:33:00]
John - SC Support - Posts: 48419
Yes, this was implemented awhile ago. Refer to the information here:
Study/Chart Alerts And Scanning: Reference by Bar Value
