Date/Time: Wed, 01 May 2024 00:22:54 +0000
Number Bars and Pullback column
View Count: 2857
[2013-04-10 07:54:17] |
FGBL07 - Posts: 19 |
When a new bar is opened and the new bar has just one price level the "old" pullback is not deleted - it will be replaced when the new bar makes a new high/low. I think when a new bar is opened the pullback column should be deleted. The pullback column display a time in the future on the x-axis. This can be confusing, I suggest to blank this time label. At the end of the day/start of new day it display data for the next day. I'm using a Constant Volume Bar chart. SC version 961. Date Time Of Last Edit: 2013-04-10 07:55:07
SNAG- 10.04.2013 09.12.37.png / V - Attached On 2013-04-10 07:53:50 UTC - Size: 45.4 KB - 900 views SNAG- 10.04.2013 07.20.20.png / V - Attached On 2013-04-10 07:54:10 UTC - Size: 67.98 KB - 902 views |
[2013-04-10 20:52:25] |
Yes, this does make sense. We are working on this.
