Date/Time: Tue, 07 May 2024 13:54:32 +0000
Interactive Brokers Options on DOM
View Count: 1161
[2013-11-19 20:31:23] |
YSS - Posts: 107 |
Hello, I try to trade options on the DOM, but it's not working. I try the IB symbol ESF4 C1800 thanks. |
[2013-11-19 21:26:27] |
What do you want us to do about this? We do not know what is meant by "not working" and Interactive Brokers options are very complex to begin with.
[2013-11-20 20:50:59] |
YSS - Posts: 107 |
It's not showing the updated traded price on the dom and I can't trade it with sierracharts. I suggest you remove 'options' from your 'about sierracharts' description. Thanks. |
