Date/Time: Thu, 08 Oct 2026 01:58:10 +0000
Custom studies on 2nd instance
View Count: 1402
[2019-03-29 13:44:00]
stever62 - Posts: 12
I have been running 2 instances of SC on the same computer for a long time - I use 1 for demo and 1 for live.
I have always had custom studies on both that I have licenses for.
Today, my first instance loaded the custom studies, but the 2nd instance did not. I tried shutting down and restarting, deleting chart and rebuilding. I got an error message that I needed a license.
Finally, I completely uninstalled my 2nd instance of SC and then reinstalled.
When I go to custom studies on 2nd instance, the only thing there is Sierra Chart Custom Studies - not my licensed ones or the User contributed ones like I see on the first instance
Date Time Of Last Edit: 2019-03-29 14:09:38
[2019-03-29 15:24:36]
Sierra Chart - Max - Posts: 5972
You need to contact the Custom Study developer about this.
Sierra Chart Support
[2019-03-29 15:29:44]
But I don't even see the User Contributed ones on the 2nd instance like I do the first - and those come from Sierra ?
[2019-03-29 16:06:59]
We are checking on this.
[2019-03-29 17:15:22]
To get the User contributed Studies, you need to reinstall Sierra Chart:
And make sure to enabled the Install Optional Components setting on the installer which is enabled by default.
In each instance of Sierra Chart go to Help >> About. Is the Account Name the same between both of them?
Also refer to:
Resolving Custom Study File and Access Issues
Otherwise, we are not identifying any issue.
Date Time Of Last Edit: 2019-03-29 17:15:47
