Date/Time: Sat, 04 May 2024 11:25:43 +0000
volume value area per bar
View Count: 1407
[2019-03-26 16:05:25] |
User175327 - Posts: 31 |
Hi- is there a way to illustrate a volume value area per bar in the number bars study. The closest approximation i can find is by coloring the volume profile setting based on "volume percentage." I am trying to draw the value area with a setting of 30%. Note i have set the "compare percent threshold" of level 3 in the number bars study to .70.....which should draw the highest 30% of volume in bar. It does do this but not as a value are. Please help: http://www.sierrachart.com/image.php?Image=1553616298386.png chart on left is numbers bars....chart on right is VbP single bar Date Time Of Last Edit: 2019-03-26 16:06:29
[2019-03-26 22:24:30] |
This is not supported in the Numbers Bars study. You would have to use the Volume by Price study as you have already done.
[2021-01-11 08:19:21] |
NotIll - Posts: 118 |
I know its an old question but you could use ''volume value area for bars'' study.
[2021-07-10 07:09:12] |
User263664 - Posts: 23 |
Thanks for that answer @NotIll you are a lifesaver.
