Date/Time: Sun, 11 Oct 2026 16:49:37 +0000
Initial Download/Setup Problem
View Count: 830
[2019-03-25 19:48:41]
Chancellor - Posts: 1
I successfully downloaded the software (I'm told) but had problems setting up the account. I did get an account setup by going to your site and using a different Account Name and Password than my first attempt. Now I have two desktop icons that both attempt to log in with the first Account Name/Password pair which are not recognized.
How can I straighten this out so that I can log in from my desktop icon and remove the duplication?
Also, I was not asked about OS or processor. Does your installation software detect that I am using Windows 7 on a 64 bit machine and install appropriately?
[2019-03-26 02:22:59]
Follow the instructions here to log in with a different account:
Sierra Chart - Software Login Instructions: Login with a Different Sierra Chart Account Name
You will see shortcuts on your desktop for the 32-bit version of Sierra Chart and 64-bit version of Sierra Chart:
Software Download: Difference Between 32 and 64-bit Versions
