Date/Time: Sun, 05 May 2024 19:43:17 +0000
Mid line for High/Low Time Period study
View Count: 1401
[2019-03-23 22:37:53] |
User972768 - Posts: 166 |
Hello, It think it would be great if you could add Mid line subgraph to the "High/Low Time Period - Extended" study. In my case all I want to chart is High, Low and Mid of the session on intraday chart (eg, 5-min). Current solution involves "Daily OHLC" study, that requires extra Daily chart of the instrument. Needless to say that it is less than elegant. If "High/Low Time Period - Extended" (and may be "High/Low Time Period") would include Mid line, then all I need is this study and minimum of extra complexity in my chartbook. Thanks and best regards Date Time Of Last Edit: 2019-03-23 22:39:32
[2019-03-25 11:59:08] |
For this you just use Study Subgraphs Average: Study Subgraphs Average Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
