Date/Time: Mon, 29 Apr 2024 06:06:19 +0000
Help with data collection
View Count: 590
[2019-03-23 15:14:39] |
User182649 - Posts: 31 |
I keep a separate chart with various stats and data for ES RTH only. This is an intraday only chart based on a 405 min bar period which constitutes the 0930-1615 RTH session for the ES. I have applied the write bar and study data study to capture this data. This data is then linked to a Google spreadsheet to generate a daily trading plan. Everything works fine except that the data from the previous day does not update until the start of the current bar at 0930. Thus, I am unable to generate the plan until the current session starts. I utilize the SC data feed with a Gain account via Stage 5. I just need the EOD data for things such as ATR, VPOC, VWAP, VAH, VAL, volume etc. Is there any way to capture this data via the write bar data study before the start of the next days sessions. Perhaps, changing the bar period or just using a historical chart. Any suggestions from SC or other users would be appreciated. Thanks |
[2019-03-24 02:24:12] |
This is possible but it requires custom programming to detect when there has actually been a close of the last bar based on the actual time.
