Date/Time: Thu, 19 Nov 2026 21:33:05 +0000
Missing ES Futures Data
View Count: 1125
[2019-03-22 00:48:49]
ged - Posts: 233
ES data (from SC) is missing today in one chartbook from 1PM PT to 4PM PT.
Computer time clock is correct.
I have deleted and redownloaded data several times from before the gap. Gap remains.
I disconnected and reconnected to SC data service. Then deleted and redownloaded. Gap remains.
I see the problem on 1H and 15M charts.
I have another chartbook also running ES data from SC.
There is no data gap in this chartbook.
Symbols, settings between the two chartbooks are identical, only the chart time periods differ.
Charts in this chartbook are 4H, 1 Day.
Would appreciate your suggestions/help.
[2019-03-22 06:25:21]
Make sure that Session Times settings are not excluding the bars within that time period for those two charts:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Incorrect Chart and Session Times Settings
[2019-03-22 12:02:50]
ged - Posts: 233
Sessions times for all charts are set as:
Start Time: 06:30:00
End Time: 14:59:59
Evening Start: 15:00:00
Evening End Time: 06:29:59
[2019-03-22 18:06:06]
This other Chartbook you mentioned that does not have the missing data, is that in the same instance of Sierra Chart?
[2019-03-22 20:44:40]
ged - Posts: 233
No, those charts are in a different instance.
[2019-03-22 20:46:52]
Ok you need to re-download the data first in the main instance of Sierra Chart and then do it again in the sub instances. This is explained here:
Using DTC Server for Data and Trading in Another Sierra Chart Instance: Historical Data and Missing Historical Data
Date Time Of Last Edit: 2019-03-22 20:47:02
