Date/Time: Sat, 18 May 2024 22:26:35 +0000
Where does Sierra source data from?
View Count: 1771
[2019-03-21 19:06:19] |
User554735 - Posts: 5 |
Hi, request to know your data source, if I can use it via an API please, because I wish to use it via an API to automate a simple trading system. Thank you
[2019-03-21 19:14:02] |
It depends upon the symbol and depends upon what the Data or Trading service is set to in Sierra Chart.
[2019-03-26 18:13:41] |
Hi, is there a difference between tick charts for CFDs and futures, specifically on S&P and WTI, regarding tick frequency possibly being different or are they the same for CFDs and Futures? If they differ, is what I am subscribed to and paying for futures tick charts as you do not trade CFDs in the USA? Thank you
[2019-03-26 21:52:18] |
Yes there is a major difference between those two different types of products. Huge difference. Sierra Chart provides historical tick by tick data for both listed futures and also CFD contracts. Location does not matter. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-26 21:52:33
[2019-03-27 06:04:24] |
Great, ok, so I am looking at tick charts on WTI and SPX futures. My question: where does Sierra source data from for these two products specifically? I want to use it via an API to automate a simple system. So knowing if the data source has changed over the past 10 years is also important, please specify if your source did change at any point. Appreciated
[2019-03-27 21:22:49] |
These come directly from the CME multicast data feed. Prior to November 2013 there are other known good sources.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-27 21:23:23
[2019-03-28 23:29:13] |
OK, one more request on this topic please: tell me where Sierra sources CFD data from, for WTI and SPX please? Appreciated
[2019-03-29 17:25:37] |
This data is provided by FXCM and LMAX.
[2020-06-16 04:46:19] |
User745789 - Posts: 173 |
Similar to above, pls confirm the source of NK225 CFD data. FXCM or LMAX? Would like to know for potential trade execution purposes. |
[2020-06-16 04:53:52] |
That CFD comes from FXCM.
