Date/Time: Sun, 05 May 2024 17:37:47 +0000
[Programming Help] - Color background on a flex renko inverse set with wick reversal bar
View Count: 1373
[2019-03-17 22:53:30] |
User701453 - Posts: 176 |
Anyone have a study formula that can be used to detect when an upward flex renko reversal bar has occurred after 4 previous flex renko down bars? If the formula could also only color background if the 3 renko bars after the reversal bar is also up with no wicks. Date Time Of Last Edit: 2019-03-17 22:58:08
[2019-03-19 08:41:30] |
No working ideas yet? Its probably not possible to get this achieved in sierra charts. |
[2019-03-24 03:28:03] |
Amazing. 53 views,posted for a week and still no working ideas. Guess the requested task is way too difficult or SC is not advanced enough to perform the requested task. |
[2019-03-24 05:37:27] |
Sawtooth - Posts: 3993 |
It's entirely possible but it's difficult to offer a formula when it's not clear what you want. Do you want to detect the 1st green renko bar after 4 red renko bars? Or do you want to detect the 3rd wickless green renko bar after 4 red renko bars? Or do you want to detect the 3rd wickless green renko bars after the 1st green renko bar after 4 red renko bars? And do you also want the reverse? And do you want both directions combined, or each unique? |
[2019-03-24 17:39:21] |
Looking to detect that pattern that will include the reversal renko bar.And do you want both directions combined, or each unique?
Separate study for long and short.I have attached a chart screenshot of what I have managed so far with the alert code. The areas circled are close to what I want. The area in the squares are painting both third and fourth bars. This is the alert code I have so far for the long side. =and( C > C[-1], C[-1] > C[-2], C[-2] > C[-3], L > L[-1], L[-3] < L [-4], L[-4] < L [-5], L[-5] < L [-6], H[-5] < H [-6] ) |
3rd bar.PNG / V - Attached On 2019-03-24 17:31:10 UTC - Size: 11.72 KB - 412 views |
[2019-03-25 02:09:58] |
Try this: =AND( ID0.SG23[-7]<ID0.SG22[-7], ID0.SG23[-6]<ID0.SG22[-6], ID0.SG23[-5]<ID0.SG22[-5], ID0.SG23[-4]<ID0.SG22[-4], ID0.SG23[-3]>ID0.SG22[-3], ID0.SG23[-2]>ID0.SG22[-2], ID0.SG23[-1]>ID0.SG22[-1], ID0.SG23[0]>ID0.SG22[0] ) This will color the 4th green bar after the 4th red bar, ignoring wicks. For the opposite direction, reverse the comparison operators. There is no formula that will consistently isolate a wickless renko bar. There is a separate identifier for renko Open and Close, but none for renko High and Low. Study/Chart Alerts And Scanning: Available Main Price Graph Identifiers/Variables |
[2019-03-26 08:35:05] |
Thanks tomgilb Works great. You are a genius. |
