Date/Time: Tue, 07 May 2024 09:06:54 +0000
changing limit order to market order in DOM via mouse (drag/drop) error
View Count: 1386
[2013-11-18 15:16:14] |
Bapovs01 - Posts: 24 |
Hello support, this is the log: FXCM FIX: Time in force type not supported, changed to Good Till Cancelled. Internal Order ID: 1071 | 2013-11-18 15:46:52 FXCM FIX: Time in force type not supported, changed to Good Till Cancelled. Internal Order ID: 1072 | 2013-11-18 15:48:00 There was an error with the order modification: Order Modification Reject. Info: 19915;DAS 19915: ZDas Exception ORA-20105: Order price did not pass validation . Service order ID: 61380248 | 2013-11-18 15:48:02 There was an error with the order modification: Order Modification Reject. Info: 19915;DAS 19915: ZDas Exception ORA-20105: Order price did not pass validation . Service order ID: 61380248 | 2013-11-18 15:48:06 FXCM FIX: Time in force type not supported, changed to Good Till Cancelled. Internal Order ID: 1073 | 2013-11-18 15:50:37 |
[2013-11-18 15:50:45] |
These are error messages from the FXCM system. This means that the system rejected the price you tried to modified the order to.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-11-18 15:50:57
