Date/Time: Fri, 03 May 2024 00:54:06 +0000
Trading Levels
View Count: 1211
[2019-03-15 12:30:53] |
007700 - Posts: 43 |
In the study list there is "Trading Levels" when added it is blank How does one get the data for this....? |
[2019-03-15 16:14:49] |
John - SC Support - Posts: 31334 |
Do you have someone who is trying to send you the data for this study and it is not showing up? Refer to the documentation here for this study: Trading Levels For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-03-15 16:41:44] |
As I am new to this not sure who to get data from Maybe the account broker....? are any suggested data provider.....? |
[2019-03-15 16:57:33] |
This study requires that the trading levels be set up through a web-based control panel page and the request identifier study Input needs to be set to access that data. This is not a study that you can use. In your case it will not display anything. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-15 16:58:16
