Date/Time: Sun, 05 May 2024 00:37:14 +0000
Chart Dom HIGH/Low Lines
View Count: 1315
[2019-03-14 16:12:31] |
Sam - Posts: 9 |
Hello, I am trying to figure out why the Chart Dom High/Low lines are showing me the globex sessions high and lows instead of daily. I did not check the Use evening session option and my daily sessions time are set correctly but the dom would still show the low line for the globex session instead of pit session. Thanks |
[2019-03-14 20:44:50] |
Those are based on the official High and Low data from the exchange. It is not changeable by session times.
