Date/Time: Tue, 07 May 2024 15:15:02 +0000
T&S Window
View Count: 703
[2019-03-13 23:14:39] |
User965825 - Posts: 15 |
Hi, is there a way to place the T&S window the way I like?Once opened, I can only change the size, but not for example put the filtered T&S above the non filtered. It´s just possible to have a 2nd T&S window next to the first. Is there a way to solve this problem? Thank you |
[2019-03-14 03:00:58] |
whats1thingnow - Posts: 407 |
hey man, you can just open another t&s window using another chart with the same symbol then re-position the two t&s windows to be above and below of one another hope that helps |
[2019-03-14 12:16:17] |
Hi Whats1thingnow, the problem is, that the windows are blocked. I can´t move them. Thank you for the response |
[2019-03-14 15:26:07] |
John - SC Support - Posts: 31429 |
Here are instructions to open another Time and Sales window: Time and Sales Window: Opening Multiple Time and Sales Windows for the Same Symbol And also note the sections below this one regarding keeping the Time and Sales window visible across Chartbooks and having the window Always on Top. We are not sure what you mean by the windows are blocked , but refer to the following information regarding Attach/Detach Window, as it sounds like this may be what you are having a problem with:Time and Sales Window: Attach/Detach Window For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
