Date/Time: Mon, 06 May 2024 01:12:07 +0000
Why my VbP indicator repaints when I maximise windows?
View Count: 629
[2019-03-13 16:56:52] |
RRHood - Posts: 15 |
Hi, idk if this is a bug or something... but why does my Vbp visible bars indicator repaint the lines when I maximise or minimize my chart window? E.g. for CLJ9, the 30min chart shows the pink line @ 57.90 now when it is half sized chart yet when I maximise it (full screen), it becomes 57.25? No difference in mouse pointing at the time bar. |
[2019-03-13 17:02:01] |
This is because the number of bars displayed is changing and you have set the Volume by Price study to be based upon the displayed bars.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-13 17:02:55
[2019-03-14 14:37:56] |
When I select "based on TPO chart" under Volume Graph Period Type it keeps resetting to "visible bars." Is this normal?
[2019-03-14 16:06:13] |
John - SC Support - Posts: 31379 |
Yes, if you do not have a TPO Profile on the Chart for the VbP to be associated with. Refer to the following for more information on the setting for Based on TPO Chart: Volume By Price Study: Based on TPO Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
