Date/Time: Thu, 10 Sep 2026 07:16:20 +0000
3/10 Oscillator Plotting Question/Suggestion
View Count: 1522
| [2019-03-13 15:21:35] |
| John - SC Support - Posts: 47822 |
First, you need to understand that what is displayed by the Bars is not just the bars for the 3/10 Oscillator values, but is the difference between the 3/10 Oscillator and the Moving Average of the 3/10 Oscillator. Therefore it is displaying properly. You will find the information on the calculations of the 3/10 Oscillator here: 3/10 Oscillator If you want to have a display that is both the line and the bars for the 3/10 Oscillator itself, then follow the instructions here to accomplish this look: Chart Studies: Displaying a Study with Both Bars and Bounding Line Just keep in mind that you will want to set the Draw Style for the Subgraphs that you do not want to display to Ignore. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-14 01:04:02
