Date/Time: Fri, 03 May 2024 15:05:00 +0000
Log - Delay adjusted UTC Date-time
View Count: 549
[2019-03-13 09:59:43] |
nicktrader - Posts: 665 |
F.US.DBM19 #9 | Performing a full recalculation because it has been tagged. Chartbook: 000 Master_slim_190119.Cht | 2019-03-13 09:53:46 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (3) | Creating socket. Using TLS 1.2. | 2019-03-13 10:42:54 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (3) | Connecting to IP: 46.4.97.203. | 2019-03-13 10:42:54 Received Date-time from server. Delay adjusted UTC Date-time: 2019-03-13 09:42:54.381. Round-trip delay: 00:00:00.229 | 2019-03-13 10:42:54 Computer time to server time difference: 00:00:00.094 | 2019-03-13 10:42:54 Error setting System Date-Time. Windows error code 1314: Dem Client fehlt ein erforderliches Recht. | 2019-03-13 10:42:54 * ==>> ... missing required rights... HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (3) | Shutdown started. Waiting for graceful close. | 2019-03-13 10:42:56 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (3) | Socket gracefully closed by remote side. | 2019-03-13 10:42:56 HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (3) | Closed. | 2019-03-13 10:42:56 What can I do to avoid this message concerning delay of Date/ time. |
[2019-03-14 01:14:32] |
For help with that error, refer to: Global Settings Menu: Set System Date-Time from Server (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
