Date/Time: Mon, 29 Apr 2024 06:34:49 +0000
Occasional trouble with entering trade with cross-hair.
View Count: 526
[2019-03-12 14:08:21] |
User388767 - Posts: 10 |
Once again having difficulty entering trades with the cross hair. Appears mostly on the "Buy" side. The window shows the price wanted but the trade goes to the market price. This problem was fixed a few months ago but is back. I haven't changed any of the settings so don't know what would cause the problem (and don't recall the steps I took to fix the problem, per your instructions, so haven't been able to go back and check the settings). Obviously, I can't trade like this. Thanks in advance for your able help. |
[2019-03-12 17:07:23] |
This is very vague for us but it sounds like the Chart DOM order type configuration is using left click operations for both Limit and Stop types. Refer to: Global Trade Settings Windows: Chart DOM Settings We do not think you should use left click operations for both Stop and Limit types. Left click should be limit types only and you can use right click for stop types. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-12 17:07:52
