Date/Time: Sat, 27 Apr 2024 23:45:08 +0000
re-centering dom immediately
View Count: 1297
[2019-03-12 09:42:19] |
User753428 - Posts: 158 |
can you enable an option to re-center the dom immediately instead of gradually when having "recenter when the last bar exceeds a certain # of ticks from center" enabled? it re-centers too slowly for fast, thin markets or esp during market open when price is moving all over the place or during big spikes during news releases. this should only take a couple lines of code, no? |
[2019-03-15 17:23:09] |
What we can do is add an option to control the speed of the re-centering.
[2019-03-15 17:25:38] |
Thank you, that would actually be a even smarter solution.
[2019-03-18 05:27:54] |
whats1thingnow - Posts: 407 |
+1 great suggestion! |
[2019-06-13 19:53:45] |
User814219 - Posts: 38 |
Yes, what I like about Xtrader or MD Trader in the TT platform is that it felt extremely responsive and re-centers immediately unlike SC's slow and gradual re-centering. Immediate re-centering matters less for thick markets like treasuries but it's useful for markets like a50, hsi, nq. |
[2019-06-16 00:54:08] |
is this done with the "adjust interval (ms)"? i tested it but don't see a difference |
[2019-06-16 03:48:43] |
This is not yet implemented but will be in about a week.
[2019-08-12 12:16:54] |
Rexz - Posts: 20 |
Is this close to being implemented yet?
[2019-08-12 17:24:34] |
Yes this is supported in the latest version of Sierra Chart which is 1971.
[2019-08-12 18:54:11] |
Rexz - Posts: 20 |
I had a look over the scale settings but couldn't find a speed option. Is it somewhere else?
[2019-08-13 02:17:12] |
This only works with a particular Constant Range Scale Mode and it is this one and we also included a screenshot: Chart Scale and Scale Adjusting: Constant Range Scale Modes >> Re-Center When The Last Bar Exceeds A Certain Number Of Ticks From The Center Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
