Date/Time: Mon, 29 Apr 2024 13:51:40 +0000
[Programming Help] - SQLite Connexion
View Count: 1085
[2019-03-12 08:01:57] |
Ch4t3 - Posts: 5 |
Dear, I try to connect my study on sql database. I have try MySQL, but so hard since 2 days. So today, I try to connect a simple SQLite to test. (the least difficult in sql) So I have add after "sierrachart.h" #include <stdio.h>
#include <sqlite3.h> and simple code like this : (connection to database to test step by step with Visual) sqlite3 *db;
char *zErrMsg = 0; int rc; rc = sqlite3_open("test.db", &db); sqlite3_close(db); And i have this message when I build : 1>MyCustomStudy.obj : error LNK2019: unresolved external symbol _sqlite3_close referenced in function _scsf_TemplateFunction
1>MyCustomStudy.obj : error LNK2019: unresolved external symbol _sqlite3_open referenced in function _scsf_TemplateFunction Thank you for your help :) PS : sqlite3.h in C:\SierraChart\ACS_Source\ and C:\SierraChart\ACS_Source\ In projet property C/C++ General -> Additional Include directories |
[2019-03-12 17:27:47] |
You have to resolve this. We cannot help with this. Clearly that function is not being found.
[2019-03-12 20:48:25] |
Ch4t3 - Posts: 5 |
Ok, Thanks you. I have find solution :) I have forget to create sqlite3.lib (+ add in projet->linker->addtional...) |
