Date/Time: Sun, 19 May 2024 18:37:01 +0000
Is there a formula or function that can get the value of the trendline I draw?
View Count: 725
[2019-03-11 04:13:16] |
User846373 - Posts: 4 |
I didn't find it in the document
[2019-03-11 14:50:35] |
John - SC Support - Posts: 31733 |
The one thing that is available for Drawing Tools is the value of the Anchor points (the entered points that define the drawing). You can access these in the Alerts. Refer to the following: Study/Chart Alerts And Scanning: Referencing Chart Drawings Otherwise, you would need to use ACSIL to create a study that can access the drawing and determine what you are looking for. Refer to the following for how to work with drawing tools: Using Drawing Tools From an Advanced Custom Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
