Date/Time: Sun, 25 Oct 2026 07:43:05 +0000
How to decrease bar spacing even further?
View Count: 2212
| [2019-03-11 03:37:09] |
| truths - Posts: 5 |
So I have reviewed this documentation https://www.sierrachart.com/index.php?l=doc/WorkingWithCharts.html#ChangingTheChartBarsPeriod But It doesn't seem to mention how to decrease it even further? I can't seem to see as much chart data as I want to. Especially on the 1 min chart |
| [2019-03-11 06:10:48] |
Other than increasing the time frame per bar, the most you can do is to reduce the chart bars spacing: Working With Charts: Changing Bar Spacing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-11 06:11:09
| [2019-03-13 00:36:39] |
| truths - Posts: 5 |
Working With Charts: Changing Bar Spacing Any reason why we are not allowed to decrease bar spacing further than that? It seems you can increase bar spacing insanely to a point where you can see half a single candle on a chart. But I can't decrease bar spacing to see more chart data which I would think is more important. TradingView charts can decrease more(tho still limited), Any chance you could add settings to decrease bar spacing even more so traders can see more chart data? |
