Date/Time: Tue, 28 May 2024 17:13:23 +0000
Sharing Market Depth files from the main instance to sub instance.
View Count: 643
[2019-03-11 01:41:02] |
User541156 - Posts: 67 |
Right now it appears that sub-instances cannot reach the market depth files already recorded by the main instance. I reckon I can copy them and that might work. But is there a better way to do this? Can sub-instance access the market depth files recorded by the main instance? Thanks. |
[2019-03-11 08:25:24] |
You do just have to copy the market depth data files over to the sub instance Data folder and do that manually.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-11 08:25:37
