Date/Time: Sat, 18 May 2024 22:46:04 +0000
Necessary to see the mapping indicator [M] while using SC real-time data service?
View Count: 557
[2019-03-10 19:23:38] |
kuba - Posts: 1 |
Is it necessary to see the mapping indicator [M] for confirmation that SC real-time data service is being used? I am running only instance of SC, connected to an IB account, using IB specific symbol for ES. Data appears to be real-time (while executing trades), but no [M] indicator after the symbol in the top line of the chart. I have followed all setup instructions for integrating with IB and do not have any other data feed except for SC real-time and historical exchange data feed. Safe to assume it's all good? Thank you |
[2019-03-10 20:33:35] |
You might be running a version that has an issue where that indicator is not displayed. Update to the current version: Software Download: Fast Update You definitely do need to have that indicator. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
