Date/Time: Sun, 19 May 2024 15:10:37 +0000
Move to Breakeven for Stop does not update Trailing Offset
View Count: 1656
[2019-03-10 10:36:44] |
User992529 - Posts: 25 |
I am trying to use a "Stop: Triggered Trail Stop" attached order with a "Move To Breakeven for Stop". When the "Trigger Offset" for the "Move To Breakeven for Stop" is reached, the stop does move to the expected level, but the "Trail Offset" still uses it's original value. I expect it should now be set to the BE "Trigger Offset" - "BE Level Offset" from the last "Move to Breakeven for Stop" command, similar as it happens for manual "moves" with the mouse. Also, if the "Stop: Triggered Trail Stop" has not been triggered yet, I would expect it's original Trail Offset to not change as the trailing is not yet active. But if it's already previously triggered and is now trailing then, any move command being either manual or automatic "Move To Breakeven for Stop", should update the "Trail Offset" automatically. NB: The option "Global Settings >> Chart Trade Settings >> Adjust Trail Offset When Modifying Trail Order" is enabled. |
[2019-03-11 21:19:14] |
We will check on this.
